Carburetor Question. Govenor/or/Carburetor Problem?
Rick
02-13-2002 17:38:11
I can't get my carburetor to idel down. I can take off the Gov. to Carb. linkage and adjusted the idel screw to idel good with my finger holding it down. When I take my finger off it revs back up. I put the gov. to carb. linkage on it and same thing, it revs back up. Do I need to rebuild the carb. or is the Govenor shot? I don't want to rebuild the carb. if the govenor is the problem. And I don't want to bother the Govenor if the Carb. is the problem. What do you guys think?
Thanks;
Jim(FL)
02-14-2002 05:55:03
 Re: Carburetor Question. Govenor/or/Carburetor Problem? in reply to Rick, 02-13-2002 17:38:11
Rick, When you have the governor linkage disconnected and you "adjusted the idel screw to idel good with my finger holding it down. When I take my finger off it revs back up." - this condition is expected because the vacuum created in the intake manifold will pull air quickly past the throttle flap and force it to a more "open" postition. Remember the throttle has no return spring to force it to the closed position (like your car's throttle) only the governor linkage /quadrant arm position (when attached) will control the throttle flapper angle. I don't think your carb or governor are the problem. You need to properly adjust the linkages.
IMHO, Jim(FL)
CD, TX
02-14-2002 05:49:49
I had the same thing. I had to adjust the linkage
from the carb to the gov.
Dell (WA)
02-13-2002 19:14:33
Rick..... ..since yer carb speeds up if'n yer governor is disconnected, that suggests that your problem is not the governor..... ...Dell
