Order Ford 8N Parts Online
What TO-20 parts fit an 8N?
Pokey
02-13-2002 18:16:52
What parts off of a TO-20 will fit an 8N? Or would be original to both tractors? I know the lift parts would be the same. Thanks, Pokey
8n in mn
02-13-2002 21:05:58
 Re: What TO-20 parts fit an 8N? in reply to Pokey, 02-13-2002 18:16:52
We purchased an 8n last summer. Upon further and closer inspection, I have arrived at the conclusion that the rear brakes, hubs, drums and axles are from the ferguson te-20 tractor. I suppose at some point, someone just tried these parts and found out they were interchangeable. So, now I'm trying to decide if I should change out these parts and replace with true 8n parts. What I have works fine, but they just ain't right on an 8n.
Ultradog MN
02-13-2002 21:28:53
 Re: Re: What TO-20 parts fit an 8N? in reply to 8n in mn, 02-13-2002 21:05:58
I think that there are plenty of Ns that have been restored to near perfect factory condition. Some of them even better maybe.
The ones that catch my eye at shows and such are the ones that are painted wrong or have some odd ball thing about them or for that matter are just regular everyday working tractors. Then they got a little character.
If I had them parts on mine I'd leave it as it is.
Talking points. You know?
Mark Hendershot
02-13-2002 21:45:17
 Re: Re: Re: What TO-20 parts fit an 8N? in reply to Ultradog MN, 02-13-2002 21:28:53
Ultradog; The Rear fender skins & mounts, differental assembley, pto shaft-lever-fork, hydralic controls, piston, cylinder,fork assembly,lift arm ram,lift arms, Pump parts, most of the Marvel Carburator parts, and more from the TO-20 are the same part number as the 9N, & 2N Tractor. According to the manuals. Mark H.
ZANE
02-13-2002 18:38:51
The lift parts will interchange. The front axle parts will interchange if the spindles stay with the axles they came from. The dimensions are the same. I'm not sure about the differential but it may be interchangable too.
The rest of the tractor is different.
Somebody may know of other parts that will interchange but I do know of these.
bg
02-13-2002 20:28:49
 Re: Re: What TO-20 parts fit an 8N? in reply to ZANE, 02-13-2002 18:38:51
Harry Ferguson supposedly published an interchange guide. I bid on one on ebay one time but didn't get it. Maybe someone else has one?
Mark Hendershot
02-13-2002 20:46:28
 Re: Re: Re: What TO-20 parts fit an 8N? in reply to bg, 02-13-2002 20:28:49
Boy I would like one of those books! Since a lot of the TO-20, and TO-30 Parts will fit a 9N, 2N also. If anyone knows where I can get one let me know please. Thanks, Mark
Guess who has one?!? :-)
02-14-2002 08:10:54
 Re: Re: Re: Re: What TO-20 parts fit an 8N? in reply to Mark Hendershot, 02-13-2002 20:46:28
Just haven't had the time to "copy" it.
When I do I'll need some smail addresses.
Will email you when I do.
Is that "tease" enough?!?!? :-)
Mark Hendershot
02-14-2002 08:31:19
 Re: Re: Re: Re: Re: What TO-20 parts fit an 8N? in reply to Guess who has one?!? :-), 02-14-2002 08:10:54
I have so many parts to get rid of it would be nice to have! I was doing it off Ebay so you guys could have a chance befor they get listed. Mark H.
Mark Hendershot
02-14-2002 08:27:37
My address is; Mark Hendershot PO Box 135 Okanogan, WA. 98840 and I would be glad to pay you for a copy. Thanks Mark H.
