Order Ford 8N Parts Online
8n front end weight
Rickiz
02-15-2002 20:10:52
Acquired a 52 8N recently with an interesting front end weight, a piece of railroad track that runs the width of the front wheels. It is welded to two support arms that are bolted into the front axle with plenty of room for the original Ford bumper. The set-up is so well made that I'm curious if it may be a factory item? If not, someone was a very good cutter and welder.
raytasch
02-16-2002 05:38:43
 Re: 8n front end weight in reply to Rickiz, 02-15-2002 20:10:52
Naw, Rickiz, Sections of rail have been used for a long time for additional weight. I have a bumper that was cobbled together with an original style Ford bumper mounted on a section of rail layin'out by the shop. Interesting thing is, it had a pipe vise attached to it also. Guy who built it was an irrigation and landscape contractor. He built it back when iron pipe was used for watering systems. I purchased a pickup a few years ago that had a section of rail made into a rear bumper. The person(s) who made your unit probably took great pride in his work. Could of been made in someone's factory but probably not Ford's. ray
