Order Ford 8N Parts Online
ARE ALL 8N TRANSmissions the same??? HELP
1951 8N
02-16-2002 17:19:51
Just dug out 1951 8N I got before Christmas, transmission locks up, took cover off, large gear (maybe 1st )has several cipped teeth. Are all of 8n trans. the same? And are parts &and trans. inter changeable??
DavidO
02-18-2002 11:21:57
 Re: ARE ALL 8N TRANSmissions the same??? HELP in reply to 1951 8N, 02-16-2002 17:19:51
Broken teeth are probably 2nd gear. Broken 2nd gear is a common problem with 8Ns. I just replaced the gears in my 48 8N with gears, I think, from a 50 8N. Get a parts manual and compare. I think that they are mostly interchangable. Only exception that I can think of is , if you have a shermon, or other aux transmission, the input/output shaft will be different.
Dave M
02-16-2002 19:34:34
I think some of the late 1952 8N's had a lower reverse gear...
