12V Broken Record
Alternator Blues recorded by Andy - Hammond, LA
Andy - Hammond,
02-17-2002 07:41:54
haha.
Well, the crisp clean air and sunny morning has refreshed my senses. Thanks for the encouragement.
Still having alternator charging issues. Hmmmmm.
Brand spanking new alternator in it this morning.
Build/Testing date of 2/3/02 on the shiny casing. Wired it up and no charge showing on the ammeter.
Checked and rechecked the wiring. One by one for continuity and quality of soldering and connection. Everything A-ok. Checked the diode going back to P1 with the VOM and it works. Voltage in one direction and not the other - Works ok.
My VOM reads that same 12,14,13,16,18,19,15,14,12,13,16 etc. same as the LAST -2- alternators. I cannot understand this. Guess I need to revive my analog meter since the field may be rendering this digital meter useless. Is this a possibility.
Ammeter show draw from ignition system but no positive movement from alternator. Any idea as to what could be causing me all of these problems.
The 8N is wired exactly according to 12V conversion specs and starts and runs fine. (as long as the battery has enough juice left)
Any help would be GREATLY appreciated. Andy
bj/8n/mt
02-17-2002 17:26:14
 Re: 12V Broken Record - Alternator Blues recorded by Andy - Hammond, LA in reply to Andy - Hammond, LA, 02-17-2002 07:41:54
Andy, kind of hard to believe you got three bad alternators. Which twelve volt diagram is yours wired like? As somebody once said there are lots of ways to convert to twelve volts and some of them even work.
When did this trouble start? Has the twelve volt system ever worked right? Can you date the onset of these symptoms to any particular event?
If Dell's suggestions don't get you going maybe the above information will help somebody recognize the trouble.
Your mileage may vary
Dell (WA)
02-17-2002 09:20:15
Andy..... ...it could be yer digital voltmeter gutts. Try connecting a filtering capacitor between the 2 meter input bannna jacks. Probably sumptin about 0.01 mfd or 0.005, not too critical.
While you didn't specify, I'm assuming you have the remote voltage sense P2 connected to the big BAT terminal on alternator, don't you?
If'n P2 connected to BAT, disconnect just the BAT wire going to the rest of the tractor wiring. With the tractor runnin, measure the BAT, should be a steady 14.9.
If'n steady alternator volts. Just measure the disconnected BAT wire, should be steady 12.6 battery volts. If'n no volts, ya ain't connected to the battery. And you won't read any charge onnna ammeter, neather. Which implies ya gotts sumptin wrong with yer wiring..... ..Dell
Phil (AZ)
02-18-2002 01:39:30
 Re: Re: 12V Broken Record - Alternator Blues recorded by Andy - Hammond, LA in reply to Dell (WA), 02-17-2002 09:20:15
Andy, As per Del, you can Excite the ALT by using a Jumper between Battery +ve and P1 (bypass the Diode)
Voltage measurements, without current flow are misleading. Try using the Wire that "was" connected to the Alt Bat conn and Jumper it to your Lights. (lamp side of Switch) Do this with Tractor OFF
What does your battery measure when Alt is Running
Be very careful with ALT's, they can Kill you if "an" int Diode shorts.
Hope this Helps,
Dave Smith
02-17-2002 09:09:53
Andy, Hold a screw driver to the rear of the alternator. If the alternator is charging you will feel the magnetism on the screw driver blade.Do you have 12 volts on the alternator side of the diode.If not the diode is backwards. Do you have 12 volts on the bat pin on the alternator. If not the alternator is not puting out. If so check downstream back to the battery till you find out where it disappears. Digital meters do not like these old tractors. I ran a post about that last week. Dell posted an idea I have not had a chance to try yet with digitals.
Dave <*)))><
