Clean,bright,tight,but not right
Paul8n
02-17-2002 14:40:59
Spend the whole day doing oil changes to all compartments. Next was new battery and them harychestedmerican cables. Check charging and nothing but battery voltage everywhere. Took out manual and I think the generator is bad. Tried the jumper to see if amp meter would change and nothing, indicating the girl has problems. Anything else I should check? Did polatirty and all connections and the belt but still nothing. Thanks for advice in advance. Paul
rasputen...reminds me of....
02-17-2002 17:20:13
 Re: Clean,bright,tight,but not right in reply to Paul8n, 02-17-2002 14:40:59
Paul,
I had my gen rebuilt last year. I had back surgery (again) and the 8N sat outside for a few months with the hood off before and after. When I got better and found no charging I discovered rust in the brush holders was causing an open circuit. I cleaned the brush holders with a small sand drum on the Dremel tool and then coated the inside surface of the holders with Antiseize. Wiped all I could off but a thin (conductive) film.
This was the KEY to MY generator problems.
Hope it helps you, or someone.
bd
bj/8n/mt
02-17-2002 17:13:53
Simple enough to check a generator. Put six volts on it--F O 4 manual tells you how. If'n it motors it will generate
Your mileage may vary
Paul8n
02-17-2002 15:14:32
I did the polarity, could I have done it wrong the second time? Or is it that once you do it it is correct? Wasn't sure the first time. Thanks, Paul
Dell (WA)
02-17-2002 21:27:53
 Re: Re: Clean,bright,tight,but not right in reply to Paul8n, 02-17-2002 15:14:32
Paul..... ....If any doubt about generator/regulator polarization, do it again. Don't hurt if'n done more than once. BUT I always haffta lookitt up innna I&T FO-4 'cuz kennn never remember howtoo dooitt. Do it wrong, annna ya burns out yer voltage regulator..... ...Dell
John,PA
02-17-2002 14:59:26
Maybe you should try polarizing the generator once.
