Zanethang
Reno
02-17-2002 19:29:49
Zane,excellent job on the live hyd. I want to put a loader on my 2N. what would be the advantage of your thang than a front pump driven unit? other than chances of it getting hit, being in front of the tractor. would yours be a cost savings? also I visted your website and you mention a different unit for different applications. what can I expect to do with the "standard thang" Two way hyd. on the boom and bucket? thanks Reno
ZANE
02-18-2002 04:14:48
 Re: Zanethang in reply to Reno, 02-17-2002 19:29:49
With the basic unit it will give you live 3 point hitch. You will be able to raise the lift without the PTO being turning.
This live hydraulics will have the same gallon per minute as the origianl pump. It will be possible to use it with any number of remote control valves but it will not be nearly as fast as the front crankshaft driven pump could be.
Yes you can operate a loader but it will be slow just like the original pump is when you tie down the lift arms and use the belly pump. With the live hydraulics though you won't have to tie down the lift arms and will still be able to use the 3 point hitch and the loader at the same time.
You would have to pay extra for the remote valves and plumbing and mounting for the valves or you can do it yourself if you are pretty good at hydraulics.
Don't that sound impossible??? It ain't!!!
