Generator okay, but what now?
Paul8n
02-20-2002 17:30:00
Am I to assume that since the generator passes all bench checks and motors fine, cleaned and re-assembled and still battery voltage everywhere that it must be the voltage regulator? Also I polarized it again. Can I check the output of the regulator? Thank you very much for all your help. Paul
steve
02-20-2002 20:11:06
 Re: Generator okay, but what now? in reply to Paul8n, 02-20-2002 17:30:00
Take the "A" and "F" wires off the generator. Ground the "F" terminal. start tractor and measure the output from the "A" to ground with a volt meter. This will tell you if the generator is good. IF you put the wires back on (they run to the G and F terminals on the regulator) and dont get voltage at the B terminal on regulator, then voltage regulator is bad.
Paul Haas - Pine Island MN
02-20-2002 19:45:20
Go to Claus's web site and follow the bouncing ball.
