Question for Dell and Beekeeper
pat
02-21-2002 12:48:49
I bought a block of beeswax and now want to apply it to the manifold studs and headbolt studs. How hot is kinda of glowing? Are we talking cherry red here or just a bit orange? Will I take the temper out of the bolts by doing this? What about the block itself?
pat
02-21-2002 19:49:51
 Re: Question for Dell and Beekeeper in reply to pat, 02-21-2002 12:48:49
Thanks Dell and Mike for your advice. I appreciate it!
MikeC
02-21-2002 18:20:17
Pat, have you tried a product called PB Blaster to remove rusted nuts and bolts? I used it for the first time last weekend and I was VERY impressed. It worked where nothing else would. Available at most auto parts stores.
Dell (WA)
02-21-2002 13:27:03
Pat..... ..think about it. Beeswax melts and burns in candle flames. not good
It pleases me that you would check the great N-Board "archives".
Scheme is to use beeswax as a release lubricant between rusty parts. Need to get beeswax liquid enuff so that capillary action will suck the stuff down the rusty joint. Then act as a lubricant when cooled off.
I don't know where you'd get the idea you'd want to get yer nuts glowing with heat. You obviously don't want the open flame of a torch to ignite the hot and melted beeswax eather..... ..Dell
pat
02-21-2002 15:09:40
 Re: Re: Question for Dell and Beekeeper in reply to Dell (WA), 02-21-2002 13:27:03
Dell,
This is what I was refering to about getting the studs hot. This is what Beekeeper said "A method I have used for several years to remove "stuck" bolts is to heat the bolt up with a propane torch until its somewhat glowing and then swab beeswax around it (a beeswax candle works well if you do not have a block of beeswax). The beeswax literally sucks itself into real tight places and will coat the threads of the bolts. You may have to reheat and repeat". He said get them somewhat glowing, hence my question about how hot do you get them and will it take the temper.
uh . . . Dell (WA)
02-21-2002 18:01:54
 Re: Re: Re: Question for Dell and Beekeeper in reply to pat, 02-21-2002 15:09:40
EXACTLY 473 deg F..... ..... .the glowing Dell
Look, your dealing with parts you should probably replace anyways, and that engine block is a great big ol' heat sink and your exhaust manifold will actually glow dull red at night when yer plowin, 'cept in daylight ya won't see it. You're probably really dealing with close to 1000 deg F.
I've used the beeswax trick on an old set of rusty discs and it does work. I don't remember getting them glowing red but some heat is involved and protection is to be recommended..... .respectfully, Dell
Ron/PA
02-21-2002 13:40:27
DELL, I loved it, perhaps your finest reply ever!!!!! ROFLMAO
Ron
