I am trying to start my NAA. It is dead and the solonoid is clicking away and the starter barely turns the engine over but it does turn over but very slowly and it doesn't start.I have a battery charger, and it is charging the 6V battery for over 1.5 hours w/o any luck it is set at 6V 30amp (the only 6V setting it has). I cleaned the connections all around. Can I use my battery charger, and switch over to 12V 30 amp, or 12V 10 amp to either charge the battery faster or use it to jump start the tractor? Questions. can I jump start it at 12V 30amp? it also has a setting for more amps for jump starting (additional to the 12 10 and 30 amp settings) can I use that setting? Can I jump start right to the starter ? and with that send current to the coil and distributor at the same time? Or, Can I just connect it right to the battery and set it 12V and push the starter button without burning out the coil or points? I briefly turned the charger to 12V while starting the push button and the starter wanted to spin fast but the engine was still slow and the solonoid was still clicking away. I can use sme help.
