Order Ford 8N Parts Online
Big Bore 8N
Ron Landrum
11-02-2000 10:14:01
Can someone tell me of any experience they have had honing the block and installing pistons to fit the block after removing the thin wall sleeves. What about power and reliability?
Thanks
Ron L
JHEnt
11-05-2000 16:13:42
 Re: Big Bore 8N in reply to Ron Landrum, 11-02-2000 10:14:01
Years ago Ford offered .090 oversized pistons to put dirrectly into the bore of the engine as a cheaper overhaul. Today these engines are deeply cut into by the piston as the cast iron used in the engine block was a soft iron. To repair one of these tractors correctly today involves sending the block to a machine shop and getting it bored and custom made sleeves installed. This is very expensive. Since the N series engine does require overhauls fairly often compared to the later overheadvalve engines you could be looking at spending alot of money every few years just for trying to get a HP boost now.
bg
11-02-2000 13:12:51
I agree with Dave. If you bore the block and run oversize pistons in the bare block, you can't rebuild it but once maybe. If you install the cast-iron sleeves you will be able to rebuild many times. The cast iron sleeves also seat the rings better and help in even heat transfer. The horsepower increase you might get is negligible, especially compared to loss of overall durability and longevity of the engine.
Dave Todd
11-02-2000 11:53:35
Ron, Why not bore the block and install the thick sleeves. That way you don't wear out the block, and it's still good for later rebuilds. If you want more power, I think you can bore the thick sleeves and put oversize pistons in, without ruining the block. Just my opinion.
Dave
Tom VB
11-02-2000 14:53:06
 Re: Re: Big Bore 8N in reply to Dave Todd, 11-02-2000 11:53:35
Dave you're correct. I have a 1950 8N which has had the 90 sleeves removed and larger pistons installed. I haven't decided what I'll do when I put it back together. My dad and many of the old hot rodders use to remove the sleeves and bore 100 ths. over then install Mercury pistons and therefore boost the power up. I've seen 100 thousands over sleeves also available.
JimTN
11-03-2000 03:31:15
 Re: Re: Re: Big Bore 8N in reply to Tom VB, 11-02-2000 14:53:06
Mercury pistons would be no different than Ford when it comes to oversize, both were same bore as the 8N to begin with, 3 3/16". Difference in Mercury piston is stroke, they had a 4" stroke so if you put a 3 3/16" Mercury piston or larger in your 8n it would not come to the top of the bore, would be shy of the top.
Dave Todd
11-02-2000 19:54:17
Tom, I would imagine there is a aleeve for just about every size hole. You might be able to find a sleeve to fit the hole and still use close to stock pistons. ??? The blocks are getting harder to find in good shape, so might as well try and save it if you can. At least you have one that can be fixed and used....I hope. Good luck!!
Dave
