Hi All,I have a 1949 8N with suspect hydraulics. I have changed over to an naa piston and o-ring. I have replaced the relief valve, cam follower pin, adjusted the linkage with Zane's adjustment jig. I dropped the pump and cleaned about 1 1/2 inches of goop from the pump housing, and still have the problem. The hydraulics work fine when you first start working the tractor, but as it warms up they get weaker. The right side seems to start getting weaker, putting more pressure on the left, and after a couple of hours it will hardly lift anything at all, bush-hog, disc, blade or any implement. I have checked for leaks, but found none. I think that the tolerances in the pump are such that it just can't pump the fluid when it gets hot. Is it time to rebuild the pump? Should the innards of the pump be rebuilt, or should the pump and chambers be reuilt? Thanks for you opinions and suggestions. Your help has been much appreciated. Rick Sisk 8n 245054
