To Calcium Chloride or to not Calcium Chloride?
Arne
02-25-2002 12:03:02
Okay, I have one tire filled with CC and one that is not. Should I fill one with CC or drain the one that is already filled? My main uses are blading dirt and snow, cutting & raking hay, cutting a pasture with a brush hog. I might try the baler and see if the N will handle it. I figure that the weight might help it be more stable for that, and it would likely help blading snow (we don't get much). OTOH, it seems like N's with too much traction can be a bad thing.
Thanks,
Arne
ZANE
02-25-2002 19:16:41
 Re: To Calcium Chloride or to not Calcium Chloride? in reply to Arne, 02-25-2002 12:03:02
Calcium Chloride eats rims!!!!! !
Danny in CO
02-25-2002 12:40:30
Arne,
I'm in the same boat as you. Both tires on my N were filled with CaCl. When I replaced one of the tires, I didn't refill. Even though the tube was not leaking, my rim was still rusted out. A replacement rim was $110. So now I have one filled and one not.
I agree with both Dell and Authur with not filling with CaCl. If I feel I need the extra weight in the future, I will use the RV antifreeze. It won't add as much weight, but will be more "user friendly".
Danny
Dell (WA)
02-25-2002 12:29:21
Arne..... ....I'm not a big fan of Calcium Chloride. That said, UNLESS you just haffta have the "additonal weight" that CaCl adds over used automobile anti-freeze (poisonous to pets) use RV holding tank anti-freeze. Anti-freeze is user friendly to rubber and tire rims.
You don't have to protect from freezing down to -50 degs (ya ain't gonna be plowin' that cold, well maybe snowplowin') down to 15-20 degs gonna make a slushie innna yer tires at -50 deg.
The only thing CaCl has going for it is cheep anti-freeze for water innna yer tires. But when you can get used from junkyards, why bother unless ya just gotta have 50# more weight.
I had my tires de-watered by professional tire outfit (service call, pick-up and delivered, no time deadline) and had "new" tubes installed ($25 ea) on my 14.9-24 rear tires for pasture mowing. So far, I haven't felt the need for weight added traction.
Your call wheather to de-water or add-water, but balance up yer rear tires. You can always use ag tire chains for added traction..... .....Dell
Arthur Brestlin
02-25-2002 12:27:22
Arne: This is a much debated subject! I am anti Calcium. In fact, I just picked up a second set of tires for my N.They are TURF TIRES since my N does a lot of mowing in an area that is rich in surface level springs. My AG tires are now "filled" and I will be draining them to enable me to single handedly swap between the two sets. I would much rather use wheel weights than deal with the shortcomings of Calcium! To me, it is easier to deal with on & off of the weights than to deal with the results of Calcium that has leaked all over your garage and began to rust all the treasures you have stored there! It also makes it humanly possible to swap between turf & AG when the need arrises. Just one mans opinion!
Arthur
