Installing proofmeter cable
Russ Nichols
02-26-2002 10:06:55
I'm installing a new cable between the governor and the proofmeter. Is the cable lubed by oil pressure from the governor? If not, do I need to get grease into it somehow before I install it? If it is lubed w/ motor oil, should I "prime" it with oil before I install it?
And I thought fixing this thing up would be simple...
thanks,
Russ
Ric-Ky.
02-26-2002 16:14:28
 Re: Installing proofmeter cable in reply to Russ Nichols, 02-26-2002 10:06:55
Here is what the owners manual says on page 122. Proof-meter Lubrication. Proof-meter is lubricated at the factory prior to assemble. Whenever it is necessary to replace cable due to cable breakage, replacement cable must be lubricated. Spread a thin layer of graphite grease over lower two-thirds of cable. When cable is reinstalled, lubricant will spread over its entire length. Over lubrication may result in failure of proof-mater.
Hope this helps...
