Paul R. in Mich
02-26-2002 15:15:27
Zane, couple weeks ago I asked for help on a 8N hydraulic problem, you were very helpful. Many thanks. Problem: Lifts, but won't drop. Move quadrant base forward, she drops, but won't lift. ?? Update: Pulled lift cover off, changed cam follower pin (worn about 1/3), adj. everything to manual spec., re-install, no better. ??? Noticed when I re-engaged the long control arm into the hyd. pump valve toggle, the arm didn't move back far enough to lower anything. Felt down inside, noticed the toggle moved back/forth easily, no resistance. Pulled the pump this morn (messy!), found lift valve was stuck halfway in, would come back out enough to stop lifting, put not enough to lower. Dis-assemble, clean, everything looks ok, re-assemble, work valve in/out a few hunded times, seems good, re-install pump, pour in fluid, she works! Plowed 1/4 mile of driveway snow, works better than ever. SO....ever see this before? P.S.: Loved your plowing story. Tell us some more.
