Order Ford 8N Parts Online
8n polarity on 48 8n
8n addict
11-03-2000 09:30:02
Battery was put in backwards and was dead. Put new battery in right way and worked fine and did not lose charge. Have used the battery for about 30 hours. I read in archives I should have repolarized generator. I tried repolarizing as suggested in archives and there was no spark when I released wires. Ampmeter is pegging away in the 1 to 5 amp charge range when tractor is running. Dips down a bit when lights are on. Am I ok and does it appear polarity is ok even if I didn't repolarize the
TimK
11-03-2000 11:36:14
 Re: 8n polarity on 48 8n in reply to 8n addict, 11-03-2000 09:30:02
Mine did exactly the same thing when I recently went to + ground. No spark when I touched the wire, and it operates just like your'un.
Claus
11-03-2000 10:44:14
You are ok.....
Claus
8n addict
11-03-2000 11:30:45
 Re: Re: 8n polarity on 48 8n in reply to Claus, 11-03-2000 10:44:14
Claus:
Thanks. Please keep on contributing to the board.
