Backfire Out the Tailpipe
Rusty
02-28-2002 18:35:04
She runs great for thirty seconds. Then she sputters and backfires out the rear. Any sugestions?
bg
02-28-2002 19:26:54
 Re: Backfire Out the Tailpipe in reply to Rusty, 02-28-2002 18:35:04
Check the gas supply and filters. Fresh gas, no water in it. Check carb adjustmen, needle valve and float level. Too lean mix will cause it. Sounds like when the float chamber is full, the thing runs OK, then when the demand for gas increases, it isn't there, then it leans out.
If the fuel system checks out, that leaves sticky valves or ignition shorting.
