Wire sizes for ignition?-6V
Reid
03-01-2002 11:56:43
All is well with the starter circuit. Obtained correct battery cables, clean and tight.
Next question is what are the correct wire gauges or sizes for:
1.Solenoid terminal to resistor block
2.Resistor to coil
3.Generator to regulator and regulator to resistor.
Sorry for the specifics, but I can't seem to find this info in the archives or on any of the wiring diagrams.
Reid
John,PA
03-01-2002 12:07:34
 Re: Wire sizes for ignition?-6V in reply to Reid, 03-01-2002 11:56:43
I think that you can get away using 14, or even 16 awg, stranded THHN cable will do. But from the genny I think I'd use 14.
John,PA
03-01-2002 12:11:05
 Re: Re: Wire sizes for ignition?-6V in reply to John,PA, 03-01-2002 12:07:34
Hey Reid, For about $15.00 you can pick-up a complete wiring harness from Ford/NewHolland, or better yet, I think I'd order one for your N thru a vendor that sponsors this site.
