BOLTS BY PTO
BOB[PA]
11-03-2000 16:46:16
I WAS WONDERING IF YOU REMOVE THESES BOLTS THAT HOLD THE STAY CHAINS ON BY THE PTO SHAFT? CHAINS HOOK TO THESE HALF MOON LOOKING THINGS.WHEN REMOVING BOLTS WILL OIL RUN OUT OF REAREND? THANKS FOR ANY HELP!!!
STUMP PULLER
11-03-2000 17:06:06
 Re: BOLTS BY PTO in reply to BOB[PA], 11-03-2000 16:46:16
NO. IF YOU REMOVE THE PTO SHAFT PARK THE FRONT END IN A DITCH, TO AVOID ANY POSSIBLE LEAKING. GOOD LUCK
