Site for inatalling/uninstalling genesee ignition?
8Nblues
03-03-2002 06:09:38
I left my ing switch on & it fried my electronic
ignition.Im going to change back to points.At the
time there was a site that had pictures of the
installiation.I need to find that site so I can
reverse the process
8Nblues
03-03-2002 16:36:43
 Re: site for inatalling/uninstalling genesee ignition? in reply to 8Nblues, 03-03-2002 06:09:38
Thanks to all for the replies,I found the site.My
8n was a 1952 conv. to 12v & worked great with
the electronic ing. for a year but when I tried to
crank it this year It wouldnt fire,I left the SW
on overnight & the next day I found the module
fried! So Ill go back to points & condenser,there
cheaper to replace.
9N'er
03-03-2002 09:55:21
This must be my lucky tractor forum day. I am converting the 850 to 12V and installing the elecronic ignition too. The link is timely for me. thanks.
Ed Gooding (VA)
03-03-2002 07:14:45
Is this what you are looking for?.
Hope this helps..... ..... Ed
'52 8N475798
Claus
03-03-2002 07:06:03
There is no reason to "fry" an electronic ignition module if the key is left on since it is not like a mechanical set of points that could be closed when on the high side of the lobe cusing continuous current through the coil primary and points. Electronic igntiions only produce a pulse when the reluctor is turning. There must have been some other latent defect to cause your problem.
Happy Motoring
Claus
Paul8n
03-03-2002 06:14:23
Don't know the site but if you leave your key on then you'll fry your points.
Phil (AZ)
03-03-2002 08:49:52
 Re: Re: site for inatalling/uninstalling genesee ignition? in reply to Paul8n, 03-03-2002 06:14:23
Paul, I disagree in 2 conditions that will not fry anything, coil or Points
1. If you have a 6V Standard Front Mount with the OEM Ballast the current is < 3 Amps.
2. If you have a Front mount 12V conversion and 6 volt Coil, with OEM ballast in series with icr-13 (or Equiv), the current is < 3 amps.
Those that convert incorrectly or bypass the ballast Resistor run the risk of high current
that will over heat the Coil but burning "GOOD" Points is questionable.
I would look at the points and if the surface has holes/material displacement, that is HI Current.
If the surface's have a pebble appearance, that is LOW current. Most likely caused when the battery died. These points can be repaired.
JMHO
