Order Ford 9N Parts Online
9n/2n hyd.
Reno J
03-03-2002 10:20:03
Condidering a backhoe attachment for my 2n, does any know how well the caddigger unit works on these tractors? and what is the operating pressure and G.P.M. of the 9n/2n? thanks in advance. Reno.
uh . . . Dell (WA)
03-03-2002 20:16:57
 Re: 9n/2n hyd. in reply to Reno J, 03-03-2002 10:20:03
Reno..... ...the N's internal hydraulics is a weak sister, about 2-1/2 gpm and about 1500 psi. Leave alone the problem of getting the hydraulics outta the tractor for remote operation. NOT GOOD IDEA.
Use a PTO operated external hydraulic pump and 10 gal resevour.
The CAD diggers have impressed me as pretty handy little units if'n yer a welder and have cheep source of iron. Otherwize, you'd probably money ahead to hire a backhoe/operator..... ...Dell
bg
03-03-2002 11:05:38
I believe that if I was going to use a 3-point mount backhoe, I'd buy an external PTO-powered pump that would give you greater and more consistent operating pressure. It would also make it easier to attach and detach. The internal pump will require chaining down the lift arms or disabling the travel range of them and would thereby limit the mobility of the backhoe.
Dave Smith
03-03-2002 12:29:52
 Re: Re: 9n/2n hyd. in reply to bg, 03-03-2002 11:05:38
I don't know if Zanes Live Thang would have volume enough to run a back hoe might be slow. I think I would go with a Pto driven pump also.
Dave <*)))><
