Hole in trans?
Rickey
03-03-2002 16:30:27
there is a 1 1/4 inch hole in the trans housing on left side right under steering box about 2 inchs down from top. could anyone tell me what its fo
Rickiz
03-03-2002 19:03:35
 Re: hole in trans? in reply to Rickey, 03-03-2002 16:30:27
I have the same sort of hole in my 8n, it's where the Sherman shift lever came out. The Sherman was removed, and the hole plugged with a rubber stopper. Stopper hasn't come out in 6 years.
Rickey
03-03-2002 19:25:43
 Re: Re: hole in trans? in reply to Rickiz, 03-03-2002 19:03:35
I guess I have to either find a step up trans or a rubber plug..... .. So I can afford a plug right now. But where?
Bill W.
03-04-2002 11:19:15
 Re: Re: Re: hole in trans? in reply to Rickey, 03-03-2002 19:25:43
Go to your local all purpose hardware store and get a l l/4 chromed plug. It has holder legs around it. Straighten every other one out and dob the circumference around the legs with appropriate amount of J.B. weld and insert in hole. Let it set overnight. It will stay. you can paint it or leave it chromed as a conversation piece.
Scott
03-03-2002 16:36:10
That is where the dealer installed Sherman over or under trans. shifter handle came out, something must have broke at it so it was removed and put back to standard.
JimNC
03-03-2002 16:34:47
Probably where a Sherman aux. trans. was in it at one time or other.
