Gas leak
Rose
03-03-2002 18:23:00
First Time this year - went to cut the grass, turned on the gas from main (under gas tank -1941 8N) At Carb bottom gas came pouring out???
What do I do??? Help!! Did a screw come out??
I turned the main off and it stopped!
If anyone knows how or what I need, please e-mail me so I can get going on moing!
Help... Rose
john,PA
03-03-2002 18:31:02
 Re: Gas leak in reply to Rose, 03-03-2002 18:23:00
There is a plug in the bottom of the carburetor which could have been removed to drain the carb. last fall. If the plug is in and is still leaking, I would suspect a stuck float.
Fast Ed Ohio
03-04-2002 00:17:27
 Re: Re: Gas leak in reply to john,PA, 03-03-2002 18:31:02
Tap Tap Tap On side of carb with plastic screwdriver handle might help un stick the float. Turn the gas on first and see if this helps , if it dont , it didnt cost nothing , good luck . Fast Ed Ohio .
