Order Ford 8N Parts Online
I need help with my 8N starter
Pete Swim
03-03-2002 20:08:37
I live in Southwest Michigan and need my 8N to plow snow but I'm having trouble with the starter. When I try to start the engine, it will crank and fire but the starter disengages before the engine actually starts up. Has anyone else had this problem? Do I just need a new starter drive, or should I rebuild/replace the entire starter? I would appreciate any help. Thanks.
Mike
03-05-2002 20:19:03
 Re: I need help with my 8N starter in reply to Pete Swim, 03-03-2002 20:08:37
Hey Pete, What Dell didn't tell you is the new starter will set you back over a hundred bucks, the new bendix starter drive should be around 30 bucks and you won't have to modify your tractor. Make sure you clean the armature shaft well and DO NOT spin the gear on the new drive, if you do, you won't be able to get it back in and will either have to disassemble the drive to reset the gear or go back to the parts store and buy another. While you have the starter out you might want to replace the brushes, if you don't feel qualified to do that yourself take the starter to a good electric motor repair shop in your area and have them do it for you. Good luck, Mike
Pete Swim
03-05-2002 23:52:15
 Re: Re: I need help with my 8N starter in reply to Mike, 03-05-2002 20:19:03
Thanks for the additional info Mike. I pulled the starter off tonight to look it over. At the very least I will put on a new bendix, and I will probably have a starter shop go through the whole thing. The armature shaft seems to have a lot of end play, about 1/8", is this normal? Thanks again.
Eric (PA)
03-04-2002 18:42:34
I had the same problem last year. Went to the New Holland dealer and bought a new starter drive assembly. Problem solved.
Eric
Dell (WA)
03-03-2002 20:24:47
Pete..... ..yep, yer starter bendix drive is onnna last leggs. Recommend replace it with one of those new "clutch" style starter drives, just a few $$$ more. You may need to grind a notch at about 1-2 o'clock for eazier starter installation.
In the mean time, make certain yer starterdrive is "squeekie clean". you might make it thru the next day or so.
Ya might also might try gettin the starter turning the motor BEFORE you turn the ignition switch on. Also a quick pull of choke before ignition switch on..... ....Dell
Bill (VA)
03-04-2002 04:39:14
 Re: Re: I need help with my 8N starter in reply to Dell (WA), 03-03-2002 20:24:47
Pushin' the starter button while choking while turning the key.. we know you can't read minds but how many arms do you have??? :)
Bill
Pete Swim
03-03-2002 21:28:55
Thanks for the info Dell. How can I tell if a starter drive is the new clutch style? Is their a certain part number, or can you suggest a drive available from one of the online parts dealers? I didn't think about the trick with cranking the engine first, then turning on the ignition, I'll try it tomorrow. I often do this with my race car in the summer when the engine is hot. Thanks again. Pete
