Generator Pulley Stuck Good
Paul8n
03-05-2002 10:56:50
Well I have tried soaking and still can't get it to budge. I could heat because this will be sent back as the core. Really don't want to put a gear puller on it cause I have heard how fragile they are and or if a replacement is available. Any thoughts or hints would be greatly appreciated. Thanks again, Paul
Paul8n 1949 Front Mount Distrubtor Has Keyway
03-05-2002 11:39:56
 Re: Generator Pulley Stuck Good in reply to Paul8n, 03-05-2002 10:56:50
Bob /Ont.
03-05-2002 15:37:08
 Re: Re: Generator Pulley Stuck Good in reply to Paul8n 1949 Front Mount Distrubtor Has Keyway, 03-05-2002 11:39:56
Hi Paul. What was the verdict on the old one, been wondering what you where doing with your gen.
Later. Bob
HB
03-05-2002 11:07:31
Paul I had to replace a bearing in mine..It was stuck also..I just put a little heat on her and she came right off..
jOHN,pa
03-05-2002 11:36:36
 Re: Re: Generator Pulley Stuck Good in reply to HB, 03-05-2002 11:07:31
If you are working with the genny that goes on the 9N, it DOES SCREW OFF, you know? I wouldn't advise a gear puller.
