Naa rebuild
randy gilbert
11-04-2000 16:45:59
I am in the process of rebuilding engine because of low compression,average 90lbs.I suspect my head is probably wore out also.there is a small groove at the top of the sleeve ,just enough to catch your fingernail on.Is this average,above,or below,just curious?
JimNC
11-04-2000 18:47:06
 Re: naa rebuild in reply to randy gilbert, 11-04-2000 16:45:59
Hey Randy, Yes the groove at the top of sleeve is normal for an engine with lots of hours on it. Mine had 20+ years on it and just did have a groove you could feel. Pulled mine down because low compression also, #1 had 110, #2 had 100, #3 had 90, #4 had 72. I had some burned valves in mine. But a bunch of other problems found after I tore it all the way down. Very Very cracked block. Check vavles good. If my block was good I would have done valve job and still be running tractor now. Instead of trying to find a block.
