Stabilizer mounting bar
Rickey
03-08-2002 20:08:14
where can I find the bracket that goes under the rear axle of an 8N for the stablizer bar.
Jay 2NSC
03-09-2002 15:18:35
 Re: stabilizer mounting bar in reply to Rickey, 03-08-2002 20:08:14
TSC has them,about $7.00.HTH Jay 2NSC
Tom-Pa
03-09-2002 11:25:03
I would recommend using the aftermarket stabilizer brackets. I found out when I was drilling one hole larger so I could attach the rear end of my snowplow frame that they have been heat treated. Like never got the holes drilled. One 3/4 inch drill bit chewed up..was able to turn it in and get another from work..they resharpen theirs..
Good luck
Tom-Pa
Jon,NH
03-09-2002 04:07:01
If you only need the bracket....you could make a bracket yourself with a good drill press and a piece of angle iron,and then buy the pin and stabilizer bar from the dealer.
John
03-08-2002 20:34:10
You mean the one that bolts on with the fender bolts. Check your local dealer. Or C-T Farm and country store or asimular store sometimes can order after market ones. John
