Bent Radius Rods
Rochester (WA)
03-08-2002 21:15:28
I've got two bowed (upwards) radius rods on my 44' 2N and would like to know if anyone has successfully straightened the hollow tubular versions. I'm considering replacing mine with the older 9N I-beam type and would like to get some opinions about whether the these earlier versions are more rigid and structurally robust--they seem to be from my estimation.
DaBrow
03-09-2002 10:28:08
 Re: Bent Radius Rods in reply to Rochester (WA), 03-08-2002 21:15:28
I've straightened a few with a 25T press & wooden blocks. Worked A1. Slow & easy is the #1 rule....DaBrow.
ZANE
03-09-2002 09:39:48
I straighten the bent radius rods by attaching my four foot pipe wrench to the front axle beside the radius rod and then attaching my five ton come along to the rear axle trumpet housing and pulling on the pipe wrench handle with the come along. This will straighten the radius rod and not put any other bends or dents in the radius rod. It will go back just exactly like it was with no bows or dents etc.
I have done many this way.
Al (NC)
03-09-2002 06:16:53
After repairing or replacing, replace yout front axle pivot bushing. Worn bushing will cause them to get bent.
Claus
03-09-2002 06:57:54
 Re: Re: Bent Radius Rods in reply to Ed Gooding (VA), 03-09-2002 06:07:14
I think you forgot the chain.
Happy Motoring
Claus
Ed Gooding (VA)
03-10-2002 06:00:33
 Re: Re: Re: Bent Radius Rods in reply to Claus, 03-09-2002 06:57:54
Chain? The one attached to my ankle on one end and a big, heavy ball on the other????
LOL..... ....Ed
Patrick Md. Va.
03-09-2002 05:39:47
You might want to check this ebay link. I just found these I beam radius rods.
bg
03-08-2002 21:33:53
I straightened one of mine with a sledge hammer. Others have reported success using a hydraulic press. I'm wondering if a tailpipe bending machine could be utilized for minor straightening?
I don't think they are as strong as the i-beam type, but with an 8N there is no option. WiIth your 2N there should be no problem fitting a set up there if you can find them. There was a set on ebay not too long ago.
