Fuel leak?
Rodney Ivers
03-13-2002 06:53:37
I recently discovered that my 8N has a fuel leak. If it sits for more than a couple days the fuel tank is empty. I tried turning off the valve at the bottom of the tank, which apparently doesn't work. I know that because the tractor runs just fine with it off and the leak continues. :(
But here's my real question. The leak seems to be coming from around the carburetor where the large hose from the air filter comes in. I suspect the gas is just filtering down through the carb and out on the air hose side. I'm not much of a carb guy. Any suggestions?
Rodney Ivers
03-13-2002 07:06:58
 Re: Fuel leak? in reply to Rodney Ivers, 03-13-2002 06:53:37
Sounds like it is unanamous. Time to order a carb rebuild kit and shut off valve.
Thanks for all the help, and man! are you guys quick.
Barnstormer
03-13-2002 07:02:34
I would say that you need a new shut-off and a carb overhaul. The first is a must. The second you can live without for awhile (if you need to).
George8NFL
03-13-2002 06:59:14
Sounds like the float is sticking?
Rodney Ivers
03-13-2002 07:02:49
 Re: Re: Fuel leak? in reply to George8NFL, 03-13-2002 06:59:14
Like I said, I'm not much on tearing apart a carb. Is a sticking float a difficult thing to fix? Would the tractor run OK, if the float was sticking, cuz it does.
