Is my governor working?
Patrick Md. Va.
03-16-2002 07:34:21
When i first start the 2n i like to run it slow till it warms up (1/4 - 1/2 throttle). When i engage the pto to lift the bush hog, it will try to stall if i do not give it some fuel. Should this happen or should the governor try to fix this near stall condition? Maybe if it was working i would be able to hog at 3/4 throttle not wide open like i am now. The hogging i do is in first gear and in very long grass and things like deep clover and honeysuckle(sp). Any tests you can give me to do? Thanks for any info. PS. I got a very old ( the original ) governor that i want to take apart and rebuild.
Claus
03-16-2002 07:47:20
 Re: Is my governor working? in reply to Patrick Md. Va., 03-16-2002 07:34:21
No, the Gov. is not working. As the engine slows under load the governor should keep the engine speed at a near constant speed. If the linkages are tight and no slop in the governor spring, it is time to rebuild. If it is not in too bad of a shape, you may get away with the short kit.
Happy Motoring
Claus
Barnstormer
03-16-2002 15:11:45
 Re: Re: Is my governor working? in reply to Claus, 03-16-2002 07:47:20
Might check linkages also. I'm sure some of you have seen some cobbled affairs on about all of the N's systems.
Dell (WA)
03-16-2002 08:39:02
Patrick..... ..what Claus sez.....plus...get yer I&T FO-4 repair manual out ($29 cheep)..... .Dell
Patrick Md. Va.
03-16-2002 15:45:34
 Re: Re: Re: Is my governor working? in reply to Dell (WA), 03-16-2002 08:39:02
Thanks guys. I do have the I&T FO-4 manual and the assembly manual. I took the original governor that has been on the shelf for the past 30 years and cleaned it up. It looks like i will need to get the master repair kit. I hope to be able to rebuild this one so that i can just switch governors when it is time. It still has lots of paint on it!
