Is this a part that i do not need?
Patrick Md. Va.
03-16-2002 16:58:36
third party image
Does this metal strap belong on the governor linkage? Look at that nice original paint. Sorry for the dark pic.
Steve IA
03-17-2002 04:31:03
 Re: Is this a part that i do not need? in reply to Patrick Md. Va., 03-16-2002 16:58:36
Patrick, When I look at the picture you posted I get an 'IMAGE TOOLBAR" in the upper right hand corner. The bar has windows icons for Save, Print, Mail, and folder something. Is this something you put on? I just reloaded my Win98 and maybe it's something that came in with the reload. Does anybody else see it? Here's what is says when I right click and click Help: "Using the image toolbar in Internet Explorer
The image toolbar makes it easy for you to save, print, or send in e-mail images that you find on the Web. The image toolbar appears when you point to an image on a Web page."
I've seen 3 World's Fairs and a goat get bred, but never seen nothing like this. Steve 8N 169302
Steve IA
03-17-2002 06:17:33
 Re: Re: Is this a part that i do not need? in reply to Steve IA, 03-17-2002 04:31:03
Yup, Upgraded to IE 6.0. among all the other things I had to do with the format/reinstall, I didn't think about that. Thanks
Hmm. Wonder what other surprises 6.0 has in store. 8^) Steve 8N 169302
Ed Gooding (VA)
03-17-2002 08:16:08
 Re: Re: Re: Is this a part that i do not need? in reply to Steve IA, 03-17-2002 06:17:33
>> Wonder what other surprises 6.0 has in store <<
Make sure that you've run the Windows Update feature from the Start menu, to ensure that the latest security patches are installed to IE 6.0.
Hope this helps..... ..... Ed
'52 8N475798
Steve IA
03-17-2002 11:32:53
 Re: Re: Re: Re: Is this a part that i do not need? in reply to Ed Gooding (VA), 03-17-2002 08:16:08
Yeah, thanks. I thought of that last night and it took 1.5 hours to download @ 26400. Steve
Ed Gooding (VA)
03-17-2002 05:03:25
Hey Steve. MikeC gave you the correct answer. It's a more user-friendly feature of IE 6.0. However, those options were always available to you. You just had to put your cursor anywhere inside a picture and right-click your mouse to see the options. IE 6.0 makes the more commonly used options (there are more than represented by the four icons) readily avaiable when your mouse cursor hovers anywhere over the image.
'52 8N475798
MikeC
03-17-2002 04:43:22
Did you upgrade to IE 6? That's a new feature.
Patrick Md. Va.
03-17-2002 04:41:54
Steve the pic looks normal to me. It is just a governor pic that i drew an arrow on to piont to a part of the linkage. Is anyone having problems? Please let me know so i can TRY to fix.
bg
03-16-2002 18:02:44
Looks like someone put a spacer in there. Probably because they couldn't get the governor adjusted right. Have you rebuilt the governor?
patrick md. va.
03-16-2002 18:52:12
 Re: Re: Is this a part that i do not need? in reply to bg, 03-16-2002 18:02:44
I think that i should remove it but wanted to be sure. I have not rebuilt it yet, just cleaned it all up so i could see what it needed.
