F M Timing: 101
Paul8n
03-17-2002 17:38:14
Put the straight edge on the tang marked "A". you can't use the side in which you turn 180 degrees. Luckily I used the correct side. This is what I was trying to explain today but must have did it incorrectly. You can barely make in out in the FO-4 manual. HTH
