Order Ford 8N Parts Online
Hooking up a remote cyn to 8N
Arne
03-18-2002 07:10:37
Okay, I hope I can 'splain this clearly. I would like to find out if I can use a remote hyd cyl to lift the sickle bar on my JD no.5 mower. I plan to mount the mower to the 11 hole draw bar and use stays to maintain the proper height. I can disconnect the lift from the lift arms. Can I then use the position lever to operate a remote hyd cyl? If so, where would the output port be on the pump? This would be a one way cyl BTW. Any input / advice appreciated.
Thanks,
Arne
Don
03-18-2002 11:14:39
 Re: Hooking up a remote cyn to 8N in reply to Arne, 03-18-2002 07:10:37
When we purchased an 8N, my brother-in-law discouraged us from getting a #5 mower. He felt the 11 hole drawbar, with lift arms, etc. were too flexible to use with a #5 mower. He was a John Deere mechanic and worked with their equipment many years. The #5 mower was the best mower made, when they were manufactured. Dad had one, on an A JD that, used a remote cylinder.
llamas
03-18-2002 11:07:48
Yes, you can do this. There's two ways.
As others have noted, your only access to the output of the internal pump is via the test port, which you have now found. As others have warned, this is NOT a NPTF (taper) port, but a straight-threaded port. It is, in fact, an SAE J514 Straight Thread O-Ring Boss (ORB) port, and the fitting you need for it is a male -05 fitting - nominal 5/16 and having a 1/2x20TPI thread. These are not as common as some, but they are available. Whatever you buy, it must be steel and rated for at least 2000 psi.
As you have heard, you will need to secure the lift arms in the down position.
Now, because of the way that the valving of the internal pump works, you will not have full control of the output using the stock touch-control lever. If you put it in "up" it will extend your cylinder until it reaches the end of the stroke, and then lift off the pressure relief valve. Your mileage may vary, but it's my opinion that that is an unwise and dangerous way to run for any period of time - the PR valve is a safety device, not a system relief to accomodate other shortcomings.
If you put the hydraulics in draft control mode, you'll have some better control - you can develop the knack of moving the touch control lever to the "neutral" condition once the cylinder has reached the extension you desire, at which point, the pump is shut off and the cylinder line closed, and it will stay where you left it. But this is a sloppy and imprecise way to get an accurtae cut-height setting.
If it were me, I would plumb the pump output to a standard three-way, open center valve, with the return line running eg to a port in one of the inspection covers and the output going to your cylinder. You would then place the stock touch-control lever in the full-up position, so that the pump runs all the time, and control the pump output with your three-way. If you put a shutoff valve in the supply line to your valve, you could close that whenever the mower was not in use, remove the stay bars, and use the TPH in the normal way.
John tOTG has an even better way of doing this, which involves some modifications to the lift cover. Check him out at www.totg.biz
HTH
llater,
llamas
Arne - Thanks Llamas
03-18-2002 13:26:54
 Re: Re: Hooking up a remote cyn to 8N in reply to llamas, 03-18-2002 11:07:48
This is not a problem. The cylinder only needs to be an up & down type thing. Mostly used to clear the sickle and when repositioning or moving to another part of the field (short distance). The sickle on a no.5 just rides on a shoe on both ends, no adjustment required other than manually.
Dave, thanks for the tip. Maybe I can add a stablizer to stiffen the draw bar. I already have the mower and not much hay to cut.
Arne
Dave
03-18-2002 10:24:55
I hooked up an external cylinder back in the fifties. Sit on the seat push on the brake closest to the tranny under you foot under the running board is a plug looks like a 3/4" nut. I bought a fitting from the Ford dealer that screwed into this hole -- FINE THREADS, NOT TAPERED---- If you can find the fitting,dont screw it in all the way, thats what the copper washer and locknut on the fitting are for. The other end of the fitting is 3/8" NPT (pipe threads). Then your ready to hook up your hydraulic hose to this. Use a Quik Coupler and fasten that to the tractor SOLID so it doesnt brake the fitting you screwed into the tractor. If you chain the lift arms down solid the hyd system will work real hard to lift them but won't be able to when you raise the 3 pt lever , the ext fills first then the internal lift cyl fills if the arms are chained down somethings got to give A CONSTANTLY SCREEMING RELIEF VALVE. Use a heavy spring to hold the arms down then when the ext cyl is full the springs allow the arms to raise normally . I used springs from an INT. 46 baler . If you have to use the lift arms at he same time the ext cyl will fill first. SOUNDS LIKE IT MIGHT WORK DOESN'T IT The hard paart is finding the fitting tho it could be made.
Dell (WA)
03-18-2002 07:24:33
Arne..... ...the general scheme to use a remote hydraulic cylinder on an N is chain down the hydraulic lift arms and use the hydraulic test port on the corner of the pump baseplate. Theres a little more to the scheme than what I've 'splained.
That said, your staybars are not strong enuff to hold down the lift arms.
Don't fully understand your need to use a remote cylinder lift on your JD #5 horsedrawn sicklebar mower converted to 3-pointlift mounted to the 11 hole drawbar. Why can't you use the N's regular hydraulics?..... ...Dell
Arne
03-18-2002 07:55:28
 Re: Re: Hooking up a remote cyn to 8N in reply to Dell (WA), 03-18-2002 07:24:33
Dell, So, the test port won't output if the lift moves too? I can chain the arms down, no problem or can also make a real heavy duty stay as long as the top mount can hold it. Reason is my no.5 (which is designed for tractor, PTO driven BTW) is already setup for a cylinder. I can use a special linkage to do as you suggest and that is an option. Just looking for the slickest way. :-)
Which is the test port on the cover plate? You said it is on a corner. Can you describe it?
Thanks,
Arne
Dell (WA)
03-18-2002 09:57:18
 Re: Re: Re: Hooking up a remote cyn to 8N in reply to Arne, 03-18-2002 07:55:28
Arne..... ..what part of "hydraulic test port on the corner of the pump baseplate" don't you understand?
You're right, I don't understand what your remote hydraulic cylinder is for. Better explain better.
Most of the time, you use your N's hydraulic lift arms to regulate the height of the cut.
Remember, a lotta and mosta of the N's competition may have had an external hydraulic pump, but only the N had the 3-point hydraulic lift until Fergusons pattents ran out and then all the tractor manufactures jumped on the 3-point bandwaggon. They recogonized a good thing..... ...Dell
Arne
03-18-2002 10:03:27
 Re: Re: Re: Re: Hooking up a remote cyn to 8N in reply to Dell (WA), 03-18-2002 09:57:18
Hi Dell,
I was sort of looking at it last night and didn't really see what looked like a test port, but reading archives see that it is located under my right heel if sitting on tractor. I will look better tonight. I think I have enough info now. Thanks for your help. (AGAIN!!) Thanks also for your patience.
Right now it seems that using the lift with mechanical linkage is the best option.
Arne
