OK fellows what ya think
A in AL
03-18-2002 14:22:15
Had my battery off for a few days. Put it on and
would not spin. Starter does not even click. I
can jump solinod and it starts. Have put meter
and has 12 volts [been converted] at solinod.
Has the solinod died or is something else going
on.
TIA Big A
Joe
03-18-2002 18:08:42
 Re: OK fellows what ya think in reply to A in AL, 03-18-2002 14:22:15
I am not really sure of your solenoid set up but check to see that the wire that becomes live at the solenoid when you try to engage the starter is hooked up properly and gets power at the solenoid when you try to turn it over. Sometimes in addition to the heavy wire hooked to the positive side of the battery there are other wires hooked directly to the battery to provide power elsewhere, through your starter switch to the solenoid This is all of course how your tractor is wired. After 50 years it is hard to tell how people have creatively wired them. Also, check the solenoid it may of happened to go bad at the same time.
