PTO ADAPTER
1951 8n Greg/Mo
03-19-2002 05:07:21
I have a 1 1/8to 1 3/8 pto adapter on the end of my pto shaft,how does it come off????
Salmoneye
03-19-2002 05:14:24
 Re: PTO ADAPTER in reply to 1951 8n Greg/Montana, 03-19-2002 05:07:21
Are you sure it is a plain adapter and not an Over Running Coupler?
Either way it is probably held on with a roll pin through the shaft. You need a drift of the appropriate size...line up the holes and tap it out...
PS
03-19-2002 05:18:35
 Re: Re: PTO ADAPTER in reply to Salmoneye, 03-19-2002 05:14:24
If it is an ORC, you will more than likely have to unscrew the grease zirks and then line up the hols in order to punch out the roll pin...
Salmoneye
