REAR ARMS FOR DRAW BARS
1951 8n Greg Mo
03-22-2002 06:14:28
My rear blade seems to wonder left and right a little bit when I"m dragging,is that normal?I was wondering if those rear stablizer arms for the draw bar set up would help keep the back blade from wondering?
PHILIP SEARCY
03-22-2002 06:50:40
 Re: REAR ARMS FOR DRAW BARS in reply to 1951 8n Greg Montana, 03-22-2002 06:14:28
THE STABILIZER BAR KIT WORKS GREAT WITH BOX SCRAPPERS, MOWERS, BUSHHOGS, BUT ARE AN ABSOLUTE MUST WHEN USING A GRADER BLADE OR BOOM POLE. THE KIT CAN BE PURCHASED FROM TRACTOR SUPPLY. YOU WILL NEED TO BOLT A MOUNT TO THE BOTTOM OF THE AXLE UNDER EACH FENDER. LONGER FENDER BOLTS MAY BE REQUIRED. THE STABILZER BARS RUN FROM THE MOUNT TO THE IMPLEMENT. LET ME KNOW IF YOU NEED ANY PICTURES OF THE COMPLETED ASSEMBLY.
Rusty 2N
03-22-2002 08:37:34
 Re: Re: REAR ARMS FOR DRAW BARS in reply to PHILIP SEARCY, 03-22-2002 06:50:40
Phil, If you could post the pcs or e-mail them to me so I can get an idea to build a set I would really appreciate this. TIA. Play safe.
Mark Hendershot
03-22-2002 08:47:51
 Re: Re: Re: REAR ARMS FOR DRAW BARS in reply to Rusty 2N, 03-22-2002 08:37:34
Rusty if you want to see a picture of the mounts Phill is talking about with the bolts see item #1714453740 on ebay there is 4 pictures of them. Mark H.
Rusty 2N
03-22-2002 09:06:17
 Re: Re: Re: Re: REAR ARMS FOR DRAW BARS in reply to Mark Hendershot, 03-22-2002 08:47:51
Thank you Mark. Are those 3 or 4 inch angles?
Mark Hendershot
03-22-2002 09:31:07
 Re: Re: Re: Re: Re: REAR ARMS FOR DRAW BARS in reply to Rusty 2N, 03-22-2002 09:06:17
Rusty; These are a Casted part. I don't think you could use angle iron due to it could bend and wear fast they are from the bottom 4 inches tall and 3 1/4 inch wide and 6 3/4 inches long. The holes for mounting the fenders thru are oblong and 4 7/8 inch on center. Alot of stress is put on this part and it should be of a harden type steel. Mark H.
Mark Hendershot
03-22-2002 09:21:33
They came off a NAA and are harden steel not just Angle Iron steel, They have several measurements which ones do you mean? Mark H.
PHILIP SEARCY
03-22-2002 06:50:34
Ken2n
03-22-2002 06:20:41
Use 2 if you use one on one side you will bend it
put one on each side
Ken2n
George Willer
03-22-2002 09:36:44
 Re: Re: REAR ARMS FOR DRAW BARS in reply to Ken2n, 03-22-2002 06:20:41
My 9N only had a bracket on the left side, and the pin wasn't quite lined up with the lift arm anchor, so I made a new pair so I could use one on each side. That may be a good idea, but the lift arms can then only work at one spacing, and are difficult to hook up. I'm only using a sway bar on one side, and it works fine. I AM using a real sway bar, and not one of the lighter adjustable stay bars. I tried to bend a slight relief bend on the end to make it easier to align the pins. A 12# sledge on the 250# anvil couldn't do it without heat. You guys are bending them??? Amazing!!!
George Willer
Mark Hendershot
03-22-2002 09:47:40
 Re: Re: Re: REAR ARMS FOR DRAW BARS in reply to George Willer, 03-22-2002 09:36:44
George; You have the real ones!! I have a set to you can't even drill a hole in them. I made a set of 2 X 3/8 steel and the first time I hooked my rear blade up and pulled some heavy snow with one it just folded. Now I have the good old ones made of real Harden Steel makes a big differents. Mark H.
Patrick Md. Va.
03-22-2002 06:56:09
Maybe i am lucky but i only have the right side bar and it has not bent in the 30 years of hard work i have done with it. I do not know how long my granfather farmed with only one. Now that i see that there are supposed to be bars on each side i will have to try to find an original bracket to go under my left fender mount.
TomP
03-22-2002 10:02:40
 Re: Re: Re: REAR ARMS FOR DRAW BARS in reply to Patrick Md. Va., 03-22-2002 06:56:09
My original Dearborn Utility Blade has only the right side designed (ie. lift pins long enough) to hook up to an anti-sway bar. The other side of the blade the lift pin is not long enough to accomodate a bar. I think the original intent was to have only one side hooked up. But would agree if you can hook up two go for it. Newer implements are designed with both pins the same length.
By the way; I learned about using anti-sway bars AFTER I ruined a perfectly good rear tractor tire with my bushhog.
Patrick Md. Va.
03-22-2002 13:57:09
 Re: Re: Re: Re: REAR ARMS FOR DRAW BARS in reply to TomP, 03-22-2002 10:02:40
I would not ruin a tire because i got the sway limiter chains short enough to not let any implement touch the tire. That is set so that the sway bar or bars do not have to be in to protect the tires.
Ken2n
03-22-2002 07:28:44
I had one on the right side only and bent it when hoggin. local farmer told me to put it on the right when hoggin because of the torque of the bush hog. I did like he said and it bent the first time out. Now I use two and have had no trouble. I got my brackets and sway bars at TSC.
LOL Ken2n
Patrick Md. Va.
03-22-2002 07:39:38
 Re: Re: Re: Re: REAR ARMS FOR DRAW BARS in reply to Ken2n, 03-22-2002 07:28:44
My grandfather told me to only use it when i hogged. I thought it was for torque, but have learned a lot since he started me out on that tractor at 13 years old. I use it now all the time for all the implements and it helps a lot, but i do see that another one would be better.
