Order Ford 8N Parts Online
Backfiring and Overheating 8N
Rusty
03-22-2002 18:49:49
Finally got her running good. After replacing the radiator, condensor, points and plugs she is doing good. But the timing seems to be impossible to set perfectly. You set it on 0 and sometimes it fires on 5 degrees. This minor problem will be battled another day. At least the backfiring, sputtering and overheating is history. And the 50 year old tractor is woking hard again.
bg
03-22-2002 20:20:13
 Re: Backfiring and Overheating 8N in reply to Rusty, 03-22-2002 18:49:49
did you check the centrifugal advance parts for wear?
