Proper steering sector alighments
Reno J
03-23-2002 16:47:00
Need help, bought two new sectors and pinion shaft for my 2n. how do you shim and align the sectors correctly? I follow my litature and when ether full right or left the wheels dont seem to be parralle but straight ahead seem to be?thanks in advance.Reno J.
bg
03-23-2002 20:24:23
 Re: proper steering sector alighments in reply to Reno J , 03-23-2002 16:47:00
The toe-in should be 1/4" when the wheels are "straight" ahead. You need to center the steering wheel with 1/2 the number of turns lock-to-lock, then adjust the drag lings to bring the wheels into alignment. The outside wheel in a turn will travel a greater distance than the inside wheel, as George has stated. That makes the inside wheel look like it is turning more sharply, which it is.
R.M. In AL
03-23-2002 21:28:39
 Re: Re: proper steering sector alighments in reply to bg, 03-23-2002 20:24:23
Hey BG: where would be the best place to check for the 1/4 in.Would you use the back of the rims and then the front of the rims about half way up? Thanks...R.M. In AL.
yep...bg
03-23-2002 21:55:41
 Re: Re: Re: proper steering sector alighments in reply to R.M. In AL, 03-23-2002 21:28:39
