PTO cap doesn't fit right ?
Patrick Md. Va.
03-25-2002 17:13:13
third party image
Shuold my (new new to me) pto cap screw on all the way or is it suposed to have a gasket to take up the gap? Just got home from 165 mile drive to play with 2n and i have some questions.
Barnstormer
03-26-2002 18:49:41
 Re: PTO cap doesn't fit right ? in reply to Patrick Md. Va., 03-25-2002 17:13:13
Patrick, by chance is the PTO shaft the original size for an N or has it been replaced by a newer STD size? Possibly the cap is bottoming on the shaft? Just a thought. I haven't looked at mine at all to know.
Patrick Md. Va.
03-26-2002 19:01:08
 Re: Re: PTO cap doesn't fit right ? in reply to Barnstormer, 03-26-2002 18:49:41
shaft is still 1 1/8. and spins freely when i have cap tight as it will go.
norbert kanzler
03-26-2002 15:29:23
check page 24 of your Master Parts catalog Models 9N,2N, 8N and NAA 1939 to 1953 part number 2N 726 Cap (power take off cover) looks different than the one you have no shoulder I would just use an "O" ring or rubber gasket
DaBrow
03-25-2002 18:29:50
Maybe the sleeve is #9N-735-B {1.00" long}instead of #9N-735-A {0.88" long}.This would be about a 1/8" difference? Just a shot in the dark...DaBrow
Patrick Md. Va.
03-25-2002 19:43:07
 Re: Re: PTO cap doesn't fit right ? in reply to DaBrow , 03-25-2002 18:29:50
What would be involved it changing out the sleeve? From looking at the books it looks like the sleeve would just pull out? Yes i know that would be too easy!
Mark Hendershot
03-25-2002 19:56:50
 Re: Re: Re: PTO cap doesn't fit right ? in reply to Patrick Md. Va., 03-25-2002 19:43:07
Patrick; Couldn't you just grind off some of the end that screws in to make it go in further? Mark H.
Patrick Md. Va. The part that my PTO cap screws into.
03-25-2002 17:39:10
third party image
The red arrow shows the peice that the cap bottems out against do yours look like this? The only way i know to fix this is cut the pto cap threads shorter. I do not want to do that!
Mark Hendershot
03-25-2002 17:18:14
Welcome back home it must be fun to play! On my original cap on the 9N it fits flush with no gasket on it. Mark H.
Patrick Md. Va.
03-25-2002 17:24:09
 Re: Re: PTO cap doesn't fit right ? in reply to Mark Hendershot, 03-25-2002 17:18:14
That is what i was afraid of! I will make gasket then. It will do till i am able to take the tractor all apart for a restore.
Mark Hendershot
03-25-2002 17:40:08
 Re: Re: Re: PTO cap doesn't fit right ? in reply to Patrick Md. Va., 03-25-2002 17:24:09
Hey! It looks good now! Put a big O-Ring on it that will seal it. Mark H.
