Tractor ID
Robert Parsons
03-26-2002 07:42:37
Serial # on engine reads 9N209527,axle part # starts with 2N.Gould this be a 1946 2N?. It also has a Ferguson System emblem on front. Please let me know Bob
bg
03-26-2002 07:47:48
 Re: Tractor ID in reply to Robert Parsons, 03-26-2002 07:42:37
yup. 1946 2N. All original 2N engines will have a 9NXXXXX serial number. If you look closely at the oval Ford badge, there should be a tiny 2N stamped in the backfround below the script Ford. The Ferguson System badge is correct. You can also check the various casting numbers on flywheel housing, axles and transmission case.
John Polesne
05-03-2002 16:43:28
 Re: Re: Tractor ID in reply to bg, 03-26-2002 07:47:48
BG,
Do you know where I could get the emblem you are talking about. I have a 2N with the Ferguson System badge, but over the years have lost the Ford emblem. A must for my restoration!!! Thanks a bunch.
John
Robert Parsons
03-26-2002 11:17:28
Thanks to bg you were exactly right. I appreciate the knowledge you people have on the tractors as this is my first
Bob
Fast Ed Ohio
03-26-2002 23:16:25
 Re: Re: Re: Tractor ID in reply to Robert Parsons , 03-26-2002 11:17:28
I had an old friend from the Akron , Ohio area that I lost track of years ago , His name was Robert L. Parsons. ( are you from this area ? )
Robert Parsons
03-27-2002 10:54:21
 Re: Re: Re: Re: Tractor ID in reply to Fast Ed Ohio, 03-26-2002 23:16:25
To Fast Fred, NO I was born and raised in Flagstaff,Az. May have relations in Ohio.I will be using my 2N in Camp Verde,Az
Bob
