Coil
Ray Oh
03-26-2002 08:52:05
Is There Anyplace I Can Buy A GOOD Frontmount Coil. Im Tired Of Paying $35 Dollars For The Cheap Made Junk. Thanks
Dave
03-26-2002 15:35:33
 Re: Coil in reply to Ray Oh, 03-26-2002 08:52:05
After going through a half dozen 12 volt coils with different combinations of resistors which lasted anywhere from 5 minutes to a few hours I think I found the right one. I'm using two ceramic resistors along with the balast on the dash and It's been working for over 20 hours and runs real good.
ED-IL
03-26-2002 09:10:35
Front mount coils are what they are.
Maybe there is something with your wiring causing them to be junk. Is your tractor a 6 volt or 12 volt system? If 6 volt, did someone bypass the resistor? If 12 volt, is there enough resistance?
uh . . . Dell (WA)
03-26-2002 09:08:33
Ray..... .....If'n you were an ignition coil manufacturer, would the marketplace support enuff sales for 2 manufacturers to compete? do the math.
Who agrees that the square frontmount ignition coil is not as robust as ya'd like 'em to be.
But if'n yer having that much trubble, you didn't just happen to remove/bypass the infamous "ballast resistor" on the backside of the dashpanel in the mistaken notion that would make hotter sparkies so yer tractor would start eazier? did ja? ..... ...just a guess..... ...Dell
I agree (ED-IL)
03-26-2002 09:16:09
 Re: Re: Coil in reply to uh . . . Dell (WA), 03-26-2002 09:08:33
Although my latest coil has lasted a little longer than the last one since I put the ballast resistor back in line.
Ray Oh
03-26-2002 11:37:00
 Re: Re: Re: Coil in reply to I agree (ED-IL), 03-26-2002 09:16:09
I Have 4Ns. All Of Them Have New Everything.6volt No Problem Starting Or Running.I Thought In 50 Years Someone Would Have Made Something That Lasts. I Go To NH Dealer& Buy A New Manifold & Its Made In India.Wont Fit Right.Buy A New hood,Wont Fit Right.New Radiator,Wont Fit Right,Made In Turkey.Spit On Coil,Wont Run.I Thought Someone Might Know Where I Could Get A Good One.Zane If You Read This Make It Your Next Project.I Am Tired Of Buying Junk.
Claus
03-26-2002 11:42:37
 Re: Re: Re: Re: Coil in reply to Ray Oh, 03-26-2002 11:37:00
Like anything else, in manufacturing "Econmy of Scale" comes into play. Only Third World Cesspools will tackle low volume and therefor we get Sh--
Happy Motoring
Claus
