Lift lever and heavy implements
Arne
03-28-2002 05:18:09
When I lift a heavier implement like my hay rake, the position control lever gets real touchy. It wants to drop right down on it's own, dropping the implement. The slightest touch or bump can cause this. The hyd's lift and hold just fine. Is there a friction or other adjustment for this?
Thanks,
Arne
steve mi
03-28-2002 09:21:03
 Re: Lift lever and heavy implements in reply to Arne, 03-28-2002 05:18:09
is that a 9N or 8N? if its the 9N it will do this ,there is no in between, I ordered the Zane thing to fix my 9N, it will be in in a week or so
It's an 8N
03-28-2002 10:33:49
 Re: Re: Lift lever and heavy implements in reply to steve mi, 03-28-2002 09:21:03
yes . . . Dell (WA)
03-28-2002 08:40:30
Arne..... ..there is suppost to be a "friction disk" behind your "Hytrol" lever. Should be obvious how to tighten..... ....respectfully, Dell
Arne --- Thanks Dell
03-28-2002 08:50:24
 Re: Re: Lift lever and heavy implements in reply to yes . . . Dell (WA), 03-28-2002 08:40:30
I'll check it out.
