What to Lube Radiator Hose With?
Arthur Brestlin
03-29-2002 03:34:17
I thought I would install my new thermostat & upper hose today.It's very difficult to get the thermostat into the hose more than 1/3 of the way. Thought about useing Vasoline lightly inside the hose.Is that a bad idea? What would you suggest?
Arthur Brestlin
03-29-2002 18:25:14
 Re: What to Lube Radiator Hose With? in reply to Arthur Brestlin, 03-29-2002 03:34:17
The hot water trick worked just fine. Thanks to everyone except Backdoor Farmer for their help.
Arthur
Jerry Johnson
09-23-2004 15:25:16
 Re: Re: What to Lube Radiator Hose With? in reply to Arthur Brestlin, 03-29-2002 18:25:14
I had the same problom.....I ended up putting the thermostat in the other end of the rad hose and pushing it to the other end. Sounds like more work but its not..... try it
Jerry
Backdoor farmer
03-29-2002 13:58:52
Oh Honey I can tell what your talk'n bout.
the best and smoothest thing to use is some of that ASTRO GLIDE, if slicker then greased hog.
Oh I'm get'n all excited....greased hog...umm lol
Al English
03-29-2002 11:40:03
Hi Arthur,
In addition to what's already been suggested, silicone is a safe lube for rubber. Silicone lubes often contain solvent thinners, which could be bad for rubber. But since these solvents evaporate quickly its not an issue. Good luck...Al English
P.S. Maybe that "Backdoor farmer" guy that posted above would have some suggestions. I'm guessing he would be an authority on lubricants
kevin
03-29-2002 07:43:57
Didja try dish soap or glycerin? (not TOO much soap)
Gaspump
03-29-2002 05:35:47
The hot water method Mike suggested should work just fine. If in the future you need grease for installing hoses, tires or other rubber products grab some vegetable based product such as Crisco from the kitchen, its the best thing to use. Petroleum products can cause rubber to deteriorate.
Mike S
03-29-2002 03:51:38
Try putting the hose in some hot water. I did that for the 8N I was working on and it softened the rubber up enough to slide the thermostat to the right place. made it easy to slide on the radiator and the inlet pipe, too.
