#1 piston
james farmer
11-08-2000 13:11:12
hello all i have my dads 52 8n and wont to tune it up. it must be 180 out because #1 is to the rear toward batt.it runs good but will it do any type of damage later on? thanking you in advance for this imformation. and many thanks to bg for overhaul information i recieve from him awhile back.good luck to all. Farmer in Ga.
Brad
11-08-2000 21:11:11
 Re: #1 piston in reply to james farmer, 11-08-2000 13:11:12
You've got the distributor 180 degrees out. Put your finger in the hole in the front cylinder and bump the motor until it blows a lot of air, that means you're on the compression stroke. Then line up the timing marks on the flywheel under the little window in the bell housing. Then you can turn the distributor or pull it out and turn it around to get #1 in the right position. It doesn't really matter, just as long as you know to time off of #4. It will sure screw up the next guy to work on it, though.
norm-wy
11-08-2000 16:21:40
James
Just follow the timing procedure in the I&T FO-4 manual. It gives you a good procedure for timing your 8N. If you don't have the manual, you really should get one from one of the sponsors of the board. It's an excellent investment. And I think I heard someone say Cheeeep the other day.
:-) FWIW
bg
11-08-2000 14:26:18
#1 is in the front. The firing order is 1-2-4-3. I'd be wanting to get it back like it's supposed to be. It's a matter of getting the #1 at top dead center and lining up the distributor to the correct location.
