Order Ford 9N Parts Online
9n steering gear housing
Art Petersen
11-08-2000 17:02:31
Where do I check and fill the steering gear housing on my 9n ford tractor/manual says fill to top of filler plug opening in side of steering gear housing but there is no plug in housing/tried filling from side bolt but fluid goes to trans/axle housing.does it get lub from the tran.?
TimK
11-09-2000 06:51:18
 Re: 9n steering gear housing in reply to Art Petersen, 11-08-2000 17:02:31
I have no idea what 9n manual you are reading, but it sounds like you've got the one dedicated to an 8n. ON the 9n-2n the steering sectors as well as the bottom shaft pinion bearing are lubricated via splash from the transmission. The steering sector arms have packing around them to keep the trans oil from leaking out. The top steering shaft bearing is lubricated with a grease gun via a zerk fitting which is on the cap which is located right below the steering wheel. Other than that, there is no other lubrication needed on the steering itself (not including tie rods etc.). The steering also is for all intents and purposes non adjustable.
1943 2N Hand Crank
11-09-2000 00:58:45
I was told by an employee of a FORD TRACTOR DEALERSHIP to replace the bearings and pack with cup-grease. It has worked for 5 years.
Art Petersen
11-08-2000 17:16:09
I think the year is 1940/ESN is hard to read . "9n226777"
Rick/Kansas
11-08-2000 17:09:38
You didn't say what year your 9n is, but I have a 1941 9n. This past summer I pretty much restored this tractor, and had the same question you asked.
'How do the sector gears get lubed?' When I took the dash and steering housing off the tractor, it appeared that fluid sloshing up from the transmission provided lubrication. I posted a question on this board and was assured that is how it is done. Doesn't look like a very efficient method, but, it has worked for 59 years.
