Order Ford 8N Parts Online
8N Trans Capacity
Pete Ellis
04-03-2002 18:03:55
what is capacity of 8 N Transmission ?
Dell (WA)
04-03-2002 20:05:07
 Re: 8N Trans Capacity in reply to Pete Ellis, 04-03-2002 18:03:55
Pete..... ..what Greg said..... .and
there are 3 drains and 1 fill up by the tranny shifter. Drain the little sq differential plug first. Its small and pees in to your bucket with some accuracy. (don't ask how I know) Then drain the 2" hydraulic, and then the 2" tranny plugs.
Fill with 5 gals of Ford/New Holland now recommended M2C-134D hydro-tranny oil. Of course you can use the 1939 Ford recommended 90wt mineral oil, if you can find it. It is NOT the same as commonally available 80-90wt gear oil..... ..Dell
Greg (NV)
04-03-2002 18:22:38
I assume you mean the fluid. Trans and rear end hold roughly 5 gallons.
Greg
Nevada
