Sleeves in engine
Robert Brown
04-06-2002 11:20:17
are the cylinder sleeves in the 4 cylinder gas engine in my 47 9n pressed in with a machine or hand pressed. the ss# has diamonds stamped next to it. Thanks guys !
Ron
04-08-2002 22:15:46
 Re: sleeves in engine in reply to Robert Brown, 04-06-2002 11:20:17
Just replaced sleeves in my 9n. I placed the sleeves in freezer overnight to shrink them Put a propane heater under engine block suspended from hoist for an hour to warm it up. Pushed sleeve very quickly into bore by hand about 1/3 way down, then placed block of wood on top of sleeve and nocked it the rest of the way home by hammering on wood. All very quickly. Worked very well, no problem. Ron
Dell (WA)
04-06-2002 11:52:41
Robert..... ...the sleeves are suppost to be an "interferance fit", which means sleeves are suppost to be bigger than the block hole.
Most take advantage of the amaizing physical propertys of metal to expand and contract with heat and use liquid nitrogen or dry ice to shrink the sleeve for a insulated hand fit..... .....respectfully, Dell
Who reminds you that there numerious "how-to's" in the "archives" at the top of this great N-Board, you might want to do some "brousing"
