Order Ford 8N Parts Online
8N not charging
Pete Misiaszek
11-09-2000 18:09:06
My 8N had new or rebuilt everything in the electrical system when I bought it two years ago. When I used it last week, I noticed it wasn't charging. I checked the belts, but everything seems fine there. What should I check next?
Salmoneye
11-10-2000 05:52:51
 Re: 8N not charging in reply to Pete Misiaszek, 11-09-2000 18:09:06
You don't say what you 'noticed' that told you it was not charging.
Did you just look at the ammeter?
If so, I would check the voltage at the battery (both off and running) with a meter.
The ammeter may have just died on you...
Mike H(MD)
11-10-2000 06:59:34
 Re: Re: 8N not charging in reply to Salmoneye, 11-10-2000 05:52:51
You also didn't say if it is a 6 or 12 volt system. If it is a 6 volt system you may have a bad voltage regulater. Get youself a meter and start checking things out. good luck Mike
