Starter
R.M. In AL.
04-06-2002 16:09:40
Hey guys: My starter went out on my 48 8n.I went to the Ford New Holland dealer and got me on of those made in China Bendix Spring and gear kits for 42 dollars.Came home and put it togather checked the ring gear which was good and replaced the starter.Started up good.Started up good 3 or four more times.Just as I was about to bushog,the tractor quit.Checked the firing nothing through the inline coil resister 12/6 volt.Called Napa and they had one for $5.95 made by Echlin.Fixed that went to start the tractor starter only buzzed did not engage.Took the starter out checked everything looked ok,put it back in started up fine.Now i'm leary of the China made spring bendix.What could have caused this,have you ever run in to this.Makes you afraid cut it off in low areas,never did like to push uphill..Thanks R.M. In AL.
I Agree With John
04-07-2002 11:36:53
 Re: Starter in reply to R.M. In AL., 04-06-2002 16:09:40
Your battery cable was not getting a good connection.
R.M. In AL.
04-07-2002 13:22:05
 Re: Re: Starter in reply to I Agree With John, 04-07-2002 11:36:53
Thats a possibility, but the cables were clean tight and bright, but during the winter could have sweated or corroated somewhat.The lights are brite etc.,but I am wondering if this would let it spin(buzz) but not engage.Its a 12 volt system. I tried it again today and it worked good,but since that happened once that will make me tighten up every time I hit the starter especially in the valleys...R.M. In AL.
John,PA
04-06-2002 16:17:43
I think that I would make sure that the battery wires are clean and tight. Also the wire from the starter solenoid to the starter. Seens like every time that you remove the starter and re-install, it works ok.
