New owner
Premie-farmer
04-06-2002 18:45:34
Hi all
I finally found a purchased a 1952 8N it's works great except the headlights are not hooked up. The wires are dry rotted and frayed I wouldn't want to hook these up the way they are. Is there a link to an 8N headlight diagram or will the 9N/2N that I found in an earlier post work? I hope to clean the tractor up and get S/N.
Dell (WA)
04-06-2002 21:23:28
 Re: New owner in reply to Premie-farmer, 04-06-2002 18:45:34
Welcome to the wonder world of N-Tractors. While they're not perfect, consider that they were designed for the horsefarmer over 65 yrs ago and they're still going strong. Great thing about N-Tractors, they work and you can entertain yourself studing over 400 implements were made to fit the cat-1 3-point hydraulic Ferguson System. Most N-parts are readily available and reasonably priced. And you can work on them yourself.
I would like to suggest that you seriously consider getting an I&T FO-4 maintenance manual. Available a many sponsors of this great N-Board. Most tractor parts emporiums, Amazon.com, www.n-news.com which has a tremendous archive of implement manuals too. Why even Ford/New Holland usually has copies available too. $29 cheap, get one and amaize yourself with newfound knowledge..... ....respectfully, Dell
MikeC
04-06-2002 18:50:45
See if this link to a page made by Tyler (thanks!) helps.
Premie-farmer
04-07-2002 10:31:30
 Re: Re: New owner in reply to MikeC, 04-06-2002 18:50:45
Yes, Mike I've seen this I take it that since this drawing is for the 9N/2N that it is compatable with the 8N as well.
not really . . . Dell (WA)
04-07-2002 16:41:26
 Re: Re: Re: New owner in reply to Premie-farmer, 04-07-2002 10:31:30
While Tylers pict-o-gram is very good and quite informative for the frontmount 2N/9N it is only semi-simular to the later sidemount 8N.
8N's have a modern generator/regulator scheme, 2N/9N's have 3rd brush generator and cutout relay. All very different.
The square frontmount ignition coil on 9N/2N/8N's use the infamous "ballast resistor" mounted on the backside of the dash panel and is quite different from the more common 6 volt round igniton can used in 8N's..... ...Dell
